Saltar al contenido principal
Harman Kardon Esquire Mini Speaker Replacement
Qué necesitas
  1. Harman Kardon Esquire Mini Speaker Replacement, Front Panel: paso 1, imagen 1 de 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Speaker Replacement: paso 2, imagen 1 de 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
  4. Harman Kardon Esquire Mini Speaker Replacement: paso 4, imagen 1 de 1
    • Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Re-do the same steps above for the other speaker to remove it.
  5. Harman Kardon Esquire Mini Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
Conclusión
15 personas más completaron esta guía.
yousef aljeemaz
Miembro Desde 10/18/17
1,039 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G9, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Miembros
5 Guías creadas
39 comentarios
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Sizino Santos - Contestar
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
mnyucel - Contestar
Hi, I also need to know where could get new replacement speaker.
Thanks
mezafernando23 -
Hi, I also need to know where could I get the replacement speaker.
Thanks
mezafernando23 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 47
Ultimos 30 días: 163
Todo El Tiempo: 19,373
