Saltar al contenido principal
Harman Kardon Esquire Mini External Stand Replacement
Qué necesitas
  1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: paso 1, imagen 1 de 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini External Stand  Replacement: paso 2, imagen 1 de 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: paso 3, imagen 1 de 1
    • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
    • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
    • After the stand is removed, replace the stand with a new one.
Conclusión
Una persona más ha completado esta guía.
yousef aljeemaz
Miembro Desde 10/18/17
1,039 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G9, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 577
