Saltar al contenido principal
Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's
Qué necesitas
  1. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's, Front Panel: paso 1, imagen 1 de 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's: paso 2, imagen 1 de 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's, Buttons and Charging Indicator Lights's: paso 3, imagen 1 de 1
    • The buttons will be on the side of the device, use the plastic opening tool to remove it from its actual place no need to use any screwdrivers.
  4. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's: paso 4, imagen 1 de 1
    • Use the plastic opening tool to remove the indicator lights and replace them by new ones.
Conclusión
yousef aljeemaz
Miembro Desde 10/18/17
1,039 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G9, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 1,449
