Introducción
This guide will go through each step required to replace the battery of a Harely-Davidson Fatboy Lo. The vehicle featured in this guide specifically, is a 2011 model. The battery listed is not the only battery that can be used for this replacement. Any 12V motorcycle battery is acceptable, and based on personal preference of the owner.
Qué necesitas
Remove the screw using the flathead screwdriver.
Following removal of the screw, lift the seat from the rear and then carefully pull the seat towards the back of the bike removing it.
This is a comprehensive guide that walks through the removal of the old battery to the installation of the new.
