Introducción
In this guide, you will learn how to replace the screen on the Handspring Visor Edge PDA. You will need tweezers, a Phillips screwdriver, and a spudger to get under the screen.
Qué necesitas
Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
