Introducción
The flip cover of the Handspring Visor Edge helps to protect the device from damage. However this cover can be delicate and occasionally snap off or require replacement. This guide shows you how to quickly remove and reattach the flip cover of the visor without the use of any extra tools.
Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
To reassemble, follow step backwards.
Una persona más ha completado esta guía.
