Saltar al contenido principal
Handspring Visor Edge Button Board Replacement
Qué necesitas
  1. Handspring Visor Edge Button Board Replacement, Flip Cover: paso 1, imagen 1 de 2 Handspring Visor Edge Button Board Replacement, Flip Cover: paso 1, imagen 2 de 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Button Board Replacement, Back Panel: paso 2, imagen 1 de 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Button Board Replacement: paso 3, imagen 1 de 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Button Board Replacement: paso 4, imagen 1 de 2 Handspring Visor Edge Button Board Replacement: paso 4, imagen 2 de 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Button Board Replacement: paso 5, imagen 1 de 2 Handspring Visor Edge Button Board Replacement: paso 5, imagen 2 de 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Button Board Replacement: paso 6, imagen 1 de 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Button Board Replacement, Button Board: paso 7, imagen 1 de 1
    • Pull off front cover gently.
  8. Handspring Visor Edge Button Board Replacement: paso 8, imagen 1 de 1
    • Remove buttons by hand, they should come off easily.
Conclusión
Nick Lazarakis
Miembro Desde 01/23/11
331 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-28, Maness Winter 2011 Miembro de Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 757
