Introducción
Use this guide to replace the Motherboard.
  1. Remove the outer screen cover by releasing  the top clip from the main body of the device. Remove the outer screen cover by releasing  the top clip from the main body of the device.
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device.
    • Pull out the stylus from the top right corner of the device.
  3. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device.
    • Slide the memory cartridge cover up and off the device.
  4. Remove the battery cover by releasing the clip from the main body of the device. Remove the battery cover by releasing the clip from the main body of the device.
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Remove the batteries from the device.
    • Remove the batteries from the device.
  7. Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  8. Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device. Be careful while opening the casing as there is a flex strip connecting the two halves. Be careful while opening the casing as there is a flex strip connecting the two halves.
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  9. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers.
    • Disconnect the flex strip from the motherboard with tweezers.
  10. Use tweezers to remove the power button from the back case.
    • Use tweezers to remove the power button from the back case.
  11. Disconnect the button pad by using the spudger to pry it off the motherboard. Remove the button pad. Remove the button pad.
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
  12. Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place. Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
    • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  13. Use the spudger to lift the motherboard from the case. Use the spudger to lift the motherboard from the case. Use the spudger to lift the motherboard from the case.
    • Use the spudger to lift the motherboard from the case.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 1-2, Regan SU 2012 Miembro de Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 709
