Saltar al contenido principal
Handspring Visor Deluxe PDA Back Cover Replacement
Qué necesitas
  1. Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: paso 1, imagen 1 de 2 Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: paso 1, imagen 2 de 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Back Cover Replacement: paso 2, imagen 1 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 2, imagen 2 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 2, imagen 3 de 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Back Cover Replacement: paso 3, imagen 1 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 3, imagen 2 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 3, imagen 3 de 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: paso 4, imagen 1 de 2 Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: paso 4, imagen 2 de 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Back Cover Replacement: paso 5, imagen 1 de 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Back Cover Replacement, Back Cover: paso 6, imagen 1 de 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Back Cover Replacement: paso 7, imagen 1 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 7, imagen 2 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 7, imagen 3 de 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Back Cover Replacement: paso 8, imagen 1 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 8, imagen 2 de 3 Handspring Visor Deluxe PDA Back Cover Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the flex strip from the motherboard with tweezers.
Conclusión
Una persona más ha completado esta guía.
Robert
Miembro Desde 07/07/12
23 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 1-2, Regan SU 2012 Miembro de Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 589
