Saltar al contenido principal
Hand-Held Blender Motor Replacement
Qué necesitas
  1. Hand-Held Blender Motor Replacement, Motor: paso 1, imagen 1 de 1
    • Place the product on a clean and empty surface.
  2. Hand-Held Blender Motor Replacement: paso 2, imagen 1 de 1
    • Twist the attachment with the blades from the base of the blender.
  3. Hand-Held Blender Motor Replacement: paso 3, imagen 1 de 1
    • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
  4. Hand-Held Blender Motor Replacement: paso 4, imagen 1 de 1
    • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
  5. Hand-Held Blender Motor Replacement: paso 5, imagen 1 de 1
    • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
    • This reveals the motor.
  6. Hand-Held Blender Motor Replacement: paso 6, imagen 1 de 1
    • Lift the motor out of the casing.
    • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
  7. Hand-Held Blender Motor Replacement: paso 7, imagen 1 de 1
    • With a soldering iron disconnect the wires coming from the motor from the PCB.
    • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 75
Todo El Tiempo: 3,362
