Saltar al contenido principal
Hamilton-T1 Air Intake and Fan Filter Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Hamilton-T1 Air Intake and Fan Filter Replacement, Air Intakes and HEPA Filter: paso 1, imagen 1 de 1
    • The fan filter is located on the side of the ventilator and can be removed and replaced by hand.
  2. Hamilton-T1 Air Intake and Fan Filter Replacement: paso 2, imagen 1 de 1
    • The air intake filter is located on the rear of the device, and can also be removed by hand.
  3. Hamilton-T1 Air Intake and Fan Filter Replacement: paso 3, imagen 1 de 1
    • To access the HEPA filter, first remove the screw holding the filter cover in place and gently remove the cover.
  4. Hamilton-T1 Air Intake and Fan Filter Replacement: paso 4, imagen 1 de 1
    • The HEPA filter can now be removed by hand.
    • Install a new HEPA filter and reattach the back panel.
    • Be sure to test the device and ensure airflow through all filters before use.
Conclusión
Trevor Foley
Miembro Desde 04/10/20
114 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G24, Paton Spring 2020 Miembro de Cal Poly, Team S11-G24, Paton Spring 2020
CPSU-PATON-S20S11G24
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 437
