Saltar al contenido principal
Hamilton-C3 Oxygen Cell Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. Hamilton-C3 Oxygen Cell Replacement, Oxygen Cell: paso 1, imagen 1 de 1
    • At the base of the ventilator housing (see diagram) is a removable cover at the far left of the panel. Open the cover by depressing the release button to expose the existing oxygen cell in its socket (see 1).
  2. Hamilton-C3 Oxygen Cell Replacement: paso 2, imagen 1 de 1
    • Pull gently to remove the electrical lead (see 2).
    • When reassembling, apply the electrical lead to the terminal until the lead locks or latches onto the terminal. Ensure that a solid contact is made with the electrical lead and take care to prevent the lead from becoming dislodged or disconnected during the installation.
  3. Hamilton-C3 Oxygen Cell Replacement: paso 3, imagen 1 de 1
    • Rotate the oxygen cell counterclockwise to remove the cell from its socket (see 3).
  4. Hamilton-C3 Oxygen Cell Replacement: paso 4, imagen 1 de 1
    • To reassemble your device, follow the instructions in reverse order.
Linea de Meta
Sophie Moffatt
Miembro Desde 04/08/20
109 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G1, Paton Spring 2020 Miembro de Cal Poly, Team S7-G1, Paton Spring 2020
CPSU-PATON-S20S7G1
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 570
