Saltar al contenido principal
Hamilton Medical Ventilator Replacing the LCD
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Hamilton Medical Ventilator Replacing the LCD, LCD: paso 1, imagen 1 de 1
    • First open the main enclosure by removing the four hexagonal-drive (Allen) screws at the rear of the enclosure.
  2. Hamilton Medical Ventilator Replacing the LCD: paso 2, imagen 1 de 1
    • Unscrew the control board mounting plate.
  3. Hamilton Medical Ventilator Replacing the LCD: paso 3, imagen 1 de 1
    • “Hinge” back the mounting plate, complete with control board. This exposes the LCD.
  4. Hamilton Medical Ventilator Replacing the LCD: paso 4, imagen 1 de 1
    • Unplug the cable from the GMP adaptor board from the LCD.
  5. Hamilton Medical Ventilator Replacing the LCD: paso 5, imagen 1 de 1
    • Unplug from the dc/ac board, the cable to the interface board.
  6. Hamilton Medical Ventilator Replacing the LCD: paso 6, imagen 1 de 1
    • Unscrew the four hexagonal-drive (Allen) screws securing the two brackets on which the LCD is mounted.
  7. Hamilton Medical Ventilator Replacing the LCD: paso 7, imagen 1 de 1
    • Lift out the complete assembly.
  8. Hamilton Medical Ventilator Replacing the LCD: paso 8, imagen 1 de 1
    • Unplug both of the lights from the dc/ac board.
  9. Hamilton Medical Ventilator Replacing the LCD: paso 9, imagen 1 de 1
    • Remove the LCD from the two brackets, by removing the black hexagonal-drive (Allen) screws on the LCD. NOTE: Do not remove the silver hexagonal-drive (Allen) screws on the SIDE of the LCD.
  10. Hamilton Medical Ventilator Replacing the LCD: paso 10, imagen 1 de 1
    • When fitting a new display, there must be an offset of approximately 2 mm between the plastic sealing strips on the LCD, and the brackets.
  11. Hamilton Medical Ventilator Replacing the LCD: paso 11, imagen 1 de 1
    • If necessary, adjust this gap using the silver screws on the side of the LCD.
    • The surface of the LCD must be clean. Wipe it free of finger marks and dust with an antistatic paper towel.
  12. Hamilton Medical Ventilator Replacing the LCD: paso 13, imagen 1 de 1
    • The cable from the GMP to the LCD must be in the cable grip on the control board mounting plate.
    • When screwing the LCD assembly into GALILEO, you must align it with the glass screen in GALILEO. Check this by looking at the front of GALILEO.
    • Turn on GALILEO, and make sure that the LCD lights up, and is properly aligned.
Conclusión
Sofya Shatalova
Miembro Desde 04/07/20
229 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G26, Paton Spring 2020 Miembro de Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 250
