Saltar al contenido principal
Hamilton Galileo Ventilator Power Supply Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Hamilton Galileo Ventilator Power Supply Replacement, Opening the Column in the Hamilton Galileo: paso 1, imagen 1 de 1
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Hamilton Galileo Ventilator Power Supply Replacement: paso 3, imagen 1 de 1
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Hamilton Galileo Ventilator Power Supply Replacement: paso 4, imagen 1 de 2 Hamilton Galileo Ventilator Power Supply Replacement: paso 4, imagen 2 de 2
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
  4. Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: paso 6, imagen 1 de 2 Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: paso 6, imagen 2 de 2
    • Remove all cables connecting power supply to GALILEO.
    • To remove the main power connector, squeeze on the two points indicated in the second picture.
    • Remove the rear cover and place it on a suitable surface.
  5. Hamilton Galileo Ventilator Power Supply Replacement: paso 8, imagen 1 de 1
    • Unscrew the retaining strip securing the power supply in its housing.
  6. Hamilton Galileo Ventilator Power Supply Replacement: paso 9, imagen 1 de 1
    • Slide the power supply out from its housing.
  7. Hamilton Galileo Ventilator Power Supply Replacement: paso 10, imagen 1 de 2 Hamilton Galileo Ventilator Power Supply Replacement: paso 10, imagen 2 de 2
    • To install the new power supply, simply do steps 5-2 in reverse.
    • Make sure the security clamp (shown in picture) is tight before reinstalling power supply.
    • Perform the internal voltage test linked here: page 7-5 of Section 7.3, Checking voltages.
    • If this test is not successful, it is likely that there is a loose connection somewhere between the internal power supply and the printed circuit boards. Check the wires to make sure they are securely fastened.
    • When the above test is successful, continue with the tests in the following sections:
    • 1) Section7, Checking hardware, voltages, and interface
    • 2) Either: Section 9, Running Original Upgrade 1 test software OR Section 10, Running Upgrade 2 test software
Conclusión
Una persona más ha completado esta guía.
Ian Van Sciver
Miembro Desde 04/09/20
332 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G26, Paton Spring 2020 Miembro de Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 502
