Saltar al contenido principal
Hamilton G5 Internal and Extended Battery Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Hamilton G5 Internal and Extended Battery Replacement, Rail: paso 1, imagen 1 de 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Internal and Extended Battery Replacement: paso 2, imagen 1 de 1
    • Remove the Rail (B).
  3. Hamilton G5 Internal and Extended Battery Replacement: paso 3, imagen 1 de 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Internal and Extended Battery Replacement, Main Cover: paso 5, imagen 1 de 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Internal and Extended Battery Replacement, Internal and Extended Battery: paso 7, imagen 1 de 1
    • Unscrew the 4 Hex Allen M4x8 screws (A), 2 on each side of the cover.
    • Lower the Front Cover (B) to remove it.
    • Disconnect the Alarm Status Display Connector (D) and set aside.
  6. Hamilton G5 Internal and Extended Battery Replacement: paso 8, imagen 1 de 1
    • Remove the 8 Hex Allen screws M4x8 (A) located on the side of the ventilator.
    • Locate internal battery (B) and slide it out.
    • Disconnect battery cable (C) and fully remove battery assembly.
  7. Hamilton G5 Internal and Extended Battery Replacement: paso 9, imagen 1 de 1
    • Remove 2 Hex Nuts, Washers, (D) and Cross Bar (E) from assembly.
    • Slide internal battery out from battery assembly.
  8. Hamilton G5 Internal and Extended Battery Replacement: paso 10, imagen 1 de 1
    • Extended Battery
    • Depress battery latch on right side (follow yellow arrow in image).
    • Slide the battery out of bracket to remove.
Conclusión
Heidi Silk
Miembro Desde 04/07/20
139 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G25, Paton Spring 2020 Miembro de Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 658
