Introducción
This guide is used to replace the motor.
Qué necesitas
Paso 1 Base Removal
Aviso: los pasos 1-5 provienen de una guía que está marcada como "En progreso".
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
Remove to electrical cap to the positive terminal(black terminal), and undo the wiring.
2 personas más completaron esta guía.
