Saltar al contenido principal
Hamilton Beach 70730 Motor Replacement
Qué necesitas
  1. Hamilton Beach 70730 Motor Replacement, Bowl: paso 1, imagen 1 de 1
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Motor Replacement: paso 2, imagen 1 de 1
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Motor Replacement: paso 3, imagen 1 de 1
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Motor Replacement: paso 4, imagen 1 de 1
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Motor Replacement: paso 5, imagen 1 de 1
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Motor Replacement, Switch: paso 6, imagen 1 de 1
    • Using a metal spudger, pry the switch from the front of the device.
  7. Hamilton Beach 70730 Motor Replacement, Drive Shaft: paso 7, imagen 1 de 1
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  8. Hamilton Beach 70730 Motor Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  9. Hamilton Beach 70730 Motor Replacement: paso 9, imagen 1 de 1
    • Using a JIS #1 driver, remove the four 10 mm screws.
  10. Hamilton Beach 70730 Motor Replacement: paso 10, imagen 1 de 1
    • Lift the driveshaft off of the base.
  11. Hamilton Beach 70730 Motor Replacement, Motor: paso 11, imagen 1 de 1
    • Reach in and remove the set of 3 gears.
  12. Hamilton Beach 70730 Motor Replacement: paso 12, imagen 1 de 1
    • Remove the four 8 mm JIS #1 screws that were revealed after removing the set of gears.
    • There will be lubricant on the screws.
  13. Hamilton Beach 70730 Motor Replacement: paso 13, imagen 1 de 1
    • Flip the device over so the bottom is visible.
  14. Hamilton Beach 70730 Motor Replacement: paso 14, imagen 1 de 1
    • Using a JIS #1 screwdriver, remove each of the four suction cups that are attached to the bottom of the food processor.
  15. Hamilton Beach 70730 Motor Replacement: paso 15, imagen 1 de 1
    • Using a JIS #1 screwdriver, remove the four 12 mm screws on the bottom.
    • The screws are recessed about 3 mm inside of the device and may not be easily visible.
  16. Hamilton Beach 70730 Motor Replacement: paso 16, imagen 1 de 1
    • Remove the two 4 mm screws underneath the on/off switch with a JIS #1 screwdriver.
  17. Hamilton Beach 70730 Motor Replacement: paso 17, imagen 1 de 1
    • Pull the bottom plate away from the base.
  18. Hamilton Beach 70730 Motor Replacement: paso 18, imagen 1 de 1
    • Using a JIS # 1 screwdriver, remove the three screws on the white bracket.
  19. Hamilton Beach 70730 Motor Replacement: paso 19, imagen 1 de 1
    • Remove the white bracket and guide the wires away from their holders. Be careful not to dislodge the spring held inside the base.
    • Be careful not to dislodge the spring on the cylindrical white piece next to it.
  20. Hamilton Beach 70730 Motor Replacement: paso 20, imagen 1 de 1
    • The motor can now be removed from the inside of the food processor.
Conclusión
4 personas más completaron esta guía.
Mack Bernard
Miembro Desde 03/08/16
597 Reputación
5 Guías creadas
Equipo
5 comentarios
Thanks for the guide! I would never have thought to dig through the grease in the gearbox to find the 4 machine screws buried under there. Turns out that my motor is fine, but the thermal fuse strapped to the windings burned out. $5 fix for a $150 device!
Louis H - Contestar
I didnt see any thermal fuse
Micah the Challenger -
On the bottom of the motor, connected to red lead, wrapped in white shielding
Fidel Cashflow - Contestar
My Hamilton Beach food processor stopped working. So I ordered another bottom part(motor assembly) but t it will not come on either. Are they not interchangeable?
nelda lowe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 54
Todo El Tiempo: 5,785
