Saltar al contenido principal
Hamilton Beach 70730 Drive Shaft Replacement
Qué necesitas
  1. Hamilton Beach 70730 Drive Shaft Replacement, Bowl: paso 1, imagen 1 de 1
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Drive Shaft Replacement: paso 2, imagen 1 de 1
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Drive Shaft Replacement: paso 3, imagen 1 de 1
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Drive Shaft Replacement: paso 4, imagen 1 de 1
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Drive Shaft Replacement: paso 5, imagen 1 de 1
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Drive Shaft Replacement, Drive Shaft: paso 6, imagen 1 de 1
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  7. Hamilton Beach 70730 Drive Shaft Replacement: paso 7, imagen 1 de 1
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  8. Hamilton Beach 70730 Drive Shaft Replacement: paso 8, imagen 1 de 1
    • Using a JIS #1 driver, remove the four 10 mm screws.
  9. Hamilton Beach 70730 Drive Shaft Replacement: paso 9, imagen 1 de 1
    • Lift the driveshaft off of the base.
Conclusión
Mack Bernard
Miembro Desde 03/08/16
597 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 743
