Saltar al contenido principal
Hamilton Beach 64650 Motor Replacement
Qué necesitas
  1. Hamilton Beach 64650 Motor Replacement, Motor: paso 1, imagen 1 de 3 Hamilton Beach 64650 Motor Replacement, Motor: paso 1, imagen 2 de 3 Hamilton Beach 64650 Motor Replacement, Motor: paso 1, imagen 3 de 3
    • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
  2. Hamilton Beach 64650 Motor Replacement: paso 2, imagen 1 de 3 Hamilton Beach 64650 Motor Replacement: paso 2, imagen 2 de 3 Hamilton Beach 64650 Motor Replacement: paso 2, imagen 3 de 3
    • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
  3. Hamilton Beach 64650 Motor Replacement: paso 3, imagen 1 de 3 Hamilton Beach 64650 Motor Replacement: paso 3, imagen 2 de 3 Hamilton Beach 64650 Motor Replacement: paso 3, imagen 3 de 3
    • Carefully pull the motor block out of the case.
    • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
    • Handle the wires with care to ensure you do not break any of them.
  4. Hamilton Beach 64650 Motor Replacement: paso 4, imagen 1 de 3 Hamilton Beach 64650 Motor Replacement: paso 4, imagen 2 de 3 Hamilton Beach 64650 Motor Replacement: paso 4, imagen 3 de 3
    • Desolder the six wires connected to the motor using this guide.
    • Make sure to note colors when you disconnect them and remember where to reconnect them later.
  5. Hamilton Beach 64650 Motor Replacement: paso 5, imagen 1 de 2 Hamilton Beach 64650 Motor Replacement: paso 5, imagen 2 de 2
    • Once disconnected, the motor will slide out easily.
Conclusión
Gwen Davis
Miembro Desde 03/24/16
519 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 66
Todo El Tiempo: 2,068
