Saltar al contenido principal
Hamilton Beach 64650 Mixer Release Button Replacement
Qué necesitas
  1. Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: paso 1, imagen 1 de 3 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: paso 1, imagen 2 de 3 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: paso 1, imagen 3 de 3
    • Depress mixer release button fully and lift mixer off of the platform.
    • Remove the bowl from the stand.
  2. Hamilton Beach 64650 Mixer Release Button Replacement: paso 2, imagen 1 de 3 Hamilton Beach 64650 Mixer Release Button Replacement: paso 2, imagen 2 de 3 Hamilton Beach 64650 Mixer Release Button Replacement: paso 2, imagen 3 de 3
    • Remove and set aside the three 1.3 mm Philips #2 screws holding the plastic cover in place.
  3. Hamilton Beach 64650 Mixer Release Button Replacement: paso 3, imagen 1 de 2 Hamilton Beach 64650 Mixer Release Button Replacement: paso 3, imagen 2 de 2
    • Shift the cover to allow the plastic retaining hook to fit through the hole easily.
    • Lift the cover away.
  4. Hamilton Beach 64650 Mixer Release Button Replacement: paso 4, imagen 1 de 3 Hamilton Beach 64650 Mixer Release Button Replacement: paso 4, imagen 2 de 3 Hamilton Beach 64650 Mixer Release Button Replacement: paso 4, imagen 3 de 3
    • Fully depress the mixer release button, pushing it through the mounting hole.
    • Push the button slightly upwards once it is inside the stand to access the spring underneath it.
    • Carefully remove the button from the stand while leaving spring in place.
  5. Hamilton Beach 64650 Mixer Release Button Replacement: paso 5, imagen 1 de 3 Hamilton Beach 64650 Mixer Release Button Replacement: paso 5, imagen 2 de 3 Hamilton Beach 64650 Mixer Release Button Replacement: paso 5, imagen 3 de 3
    • Depress the spring slightly and lift upward to remove.
    • Replace with a new spring to have a working button again.
Conclusión
Gwen Davis
Miembro Desde 03/24/16
519 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 1,289
