Saltar al contenido principal
Hamilton Beach 51101BA Motor Replacement
Qué necesitas
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: paso 1, imagen 1 de 3 Hamilton Beach 51101BA Motor Replacement, Rotor: paso 1, imagen 2 de 3 Hamilton Beach 51101BA Motor Replacement, Rotor: paso 1, imagen 3 de 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Motor Replacement: paso 2, imagen 1 de 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Motor Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Motor Replacement: paso 4, imagen 1 de 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Motor Replacement: paso 5, imagen 1 de 2 Hamilton Beach 51101BA Motor Replacement: paso 5, imagen 2 de 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Motor Replacement: paso 6, imagen 1 de 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
  7. Hamilton Beach 51101BA Motor Replacement, Motor: paso 7, imagen 1 de 2 Hamilton Beach 51101BA Motor Replacement, Motor: paso 7, imagen 2 de 2
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
  8. Hamilton Beach 51101BA Motor Replacement: paso 8, imagen 1 de 1
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
  9. Hamilton Beach 51101BA Motor Replacement: paso 9, imagen 1 de 1
    • Cut the thin black wire from the wire cap.
Conclusión
Andrew Huff
Miembro Desde 09/04/15
568 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-5, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Miembros
5 Guías creadas
2 comentarios
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Contestar
Que tipo de motor tengo que comprar?
hugoalex521 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 72
Todo El Tiempo: 7,022
