Introducción
This replacement requires you to be confident with simple wiring as well as basic soldering skills. If you are unfamiliar with soldering and de-soldering, make sure to check out iFixit's Soldering Skills page before attempting this replacement!
Qué necesitas
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
Remove the two 10mm screws connecting the thermal switch with the PH2 Screwdriver and a bit of force.
