Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This is a straight-forward process that requires removal of a few screws and two wire caps.
  1. Unplug your device before proceeding with disassembly. Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Lift up the plastic cover to expose the plug wiring.
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps. Slide off the white cap. Repeat these steps for the second white cap.
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Remove the two rubber screw covers from the bottom of the Panini Press. Remove the four uncovered 10mm screws with the PH2 Screwdriver.
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely. Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
Conclusión
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
2 personas más completaron esta guía.
Maxwell Taylor
Miembro Desde 08/02/15
149 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-27, Amido Winter 2015 Miembro de Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 358
