Introducción
This a replacement that requires good soldering skills and confidence working with tiny, delicate, wiring.
If you are unfamiliar with soldering and de-soldering, make sure to check out iFixit's Soldering Skills page before attempting this replacement!
Qué necesitas
On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
Repeat for the other washer across from the first one.
Gently separate the heating element housing from the cooking surface by pulling up on the housing and pushing down on the surface.
