Introducción
Is your hair dryer only blowing cold air? You most likely need a new heating element. Use this guide if you are looking to remove and replace a heating element for any standard electric hair dryer. You will save money and learn more about your handheld dryer. You will need a screwdriver (most likely Phillips head) , a desoldering wick, and a soldering iron. For information about soldering/desoldering, please review this guide as it does require specific skills. As always, please solder in a well ventilated area. If your hair dryer is sensitive, be sure sure to work with electrostatic discharge (ESD) -safe tools in an ESD-safe environment.
Herramientas
Partes
No se especificaron partes.
Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
Locate the screws on the handle of dryer and remove them with a Phillips head screwdriver.
Isolate the heating element.
Use a desoldering wick and soldering iron to desolder the wires. Refer to this soldering page for more information on soldering.
To reassemble your device, follow these instructions in reverse order. Make sure wiring is enclosed in body of hair dryer and heating element casing is attached properly before screwing it closed.
7 personas más completaron esta guía.
