Saltar al contenido principal
Hair Dryer Grating Replacement
Qué necesitas
  1. Hair Dryer Grating Replacement, Nozzle: paso 1, imagen 1 de 2 Hair Dryer Grating Replacement, Nozzle: paso 1, imagen 2 de 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Grating Replacement, Grating: paso 2, imagen 1 de 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Grating Replacement: paso 3, imagen 1 de 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Grating Replacement: paso 4, imagen 1 de 1
    • Separate the hair dryer grating into the three pieces seen in the image.
Conclusión
Mitch
Miembro Desde 10/04/12
34 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 24-29, Regan Fall 2012 Miembro de Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 2,499
