Saltar al contenido principal
HUAWEI HONOR 5X Front And Back Camera Replacement
Qué necesitas
  1. HUAWEI HONOR 5X Front And Back Camera Replacement, HUAWEI HONOR 5X Disassembly: paso 1, imagen 1 de 1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 2, imagen 1 de 1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 3, imagen 1 de 2 HUAWEI HONOR 5X Front And Back Camera Replacement: paso 3, imagen 2 de 2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 4, imagen 1 de 1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 5, imagen 1 de 2 HUAWEI HONOR 5X Front And Back Camera Replacement: paso 5, imagen 2 de 2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Front And Back Camera Replacement, Motherboard: paso 6, imagen 1 de 2 HUAWEI HONOR 5X Front And Back Camera Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 7, imagen 1 de 2 HUAWEI HONOR 5X Front And Back Camera Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 8, imagen 1 de 3 HUAWEI HONOR 5X Front And Back Camera Replacement: paso 8, imagen 2 de 3 HUAWEI HONOR 5X Front And Back Camera Replacement: paso 8, imagen 3 de 3
    • Remove the motherboard.
  9. HUAWEI HONOR 5X Front And Back Camera Replacement, Front And Back Camera: paso 9, imagen 1 de 1
    • Use a plastic opening tool to pry up and disconnect the camera from the motherboard.
  10. HUAWEI HONOR 5X Front And Back Camera Replacement: paso 10, imagen 1 de 1
    • Use a plastic opening tool to pry the front camera connector from its socket on the motherboard.
Conclusión
Klara Asllani
Miembro Desde 01/25/18
788 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G6, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G6, Passmore Spring 2018
USFT-PASSMORE-S18S7G6
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 394
