Saltar al contenido principal
HUAWEI HONOR 5X Battery Replacement
Qué necesitas
  1. HUAWEI HONOR 5X Battery Replacement, HUAWEI HONOR 5X Disassembly: paso 1, imagen 1 de 1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Battery Replacement: paso 3, imagen 1 de 2 HUAWEI HONOR 5X Battery Replacement: paso 3, imagen 2 de 2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Battery Replacement: paso 4, imagen 1 de 1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Battery Replacement: paso 5, imagen 1 de 2 HUAWEI HONOR 5X Battery Replacement: paso 5, imagen 2 de 2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Remove the pink sticker.
  7. HUAWEI HONOR 5X Battery Replacement: paso 7, imagen 1 de 1
    • Remove the three 1.5mm Phillips #000 screws.
  8. HUAWEI HONOR 5X Battery Replacement: paso 8, imagen 1 de 2 HUAWEI HONOR 5X Battery Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  9. HUAWEI HONOR 5X Battery Replacement: paso 9, imagen 1 de 1
    • Remove the battery from the phone.
Conclusión
7 personas más completaron esta guía.
Klara Asllani
Miembro Desde 01/25/18
788 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G6, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G6, Passmore Spring 2018
USFT-PASSMORE-S18S7G6
3 Miembros
12 Guías creadas
4 comentarios
Just did this successfully, thanks for the steps.
I’d suggest adding to BE CAREFUL WHEN PRYING OUT THE BATTERY. #1 there is the screen cable under there and if you damage that, then have fun getting a new screen. #2 lithium batteries can ignite when punctured (like I did). Go easy working your way in and take note of where the screen cable is (lower black cable in step 9 image).
russellvinegar - Contestar
11/09/19 - What is this pink sticker called so I can purchase a replacement? Can copper foil, conducive tape be used in place of the clear pink sticker? I would appreciate answers to both questions please. Thank you.
RJEFFRIES - Contestar
Anyone know where I can get replacement 1.17mm Torx T3 screws? Mine came stripped. I had a tough time getting them out and don’t want to use the same ones to put back in.
Melissa Padilla - Contestar
I have an Honor 5x, model KIW-L24. It has T2 torx screws, not T3, at the bottom, and I am totally unable to open it after removing the screws and the two SIM trays, Is mine somehow different?
Bob Brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 29
Ultimos 30 días: 37
Todo El Tiempo: 5,967
