Saltar al contenido principal
HTC myTouch 3G Camera Replacement
Qué necesitas
  1. HTC myTouch 3G Camera Replacement, Remove the Cover: paso 1, imagen 1 de 2 HTC myTouch 3G Camera Replacement, Remove the Cover: paso 1, imagen 2 de 2
    • Press both thumbs on each side of the upper corners, and apply pressure in a downward motion.
    • While applying downward pressure, slide the back cover down and off the phone.
  2. HTC myTouch 3G Camera Replacement, Remove Battery and SIM Card: paso 2, imagen 1 de 2 HTC myTouch 3G Camera Replacement, Remove Battery and SIM Card: paso 2, imagen 2 de 2
    • Remove the battery.
    • Remove the SIM card.
  3. HTC myTouch 3G Camera Replacement, Remove SD Card: paso 3, imagen 1 de 1
    • Push the SD card in to eject it.
    • Pull the SD card out.
  4. HTC myTouch 3G Camera Replacement, Remove Back Panel Screws: paso 4, imagen 1 de 2 HTC myTouch 3G Camera Replacement, Remove Back Panel Screws: paso 4, imagen 2 de 2
    • Remove the four 6 mm T5 Torx screws from the four corners on the back of the phone.
    • Remove the two 4 mm T5 Torx screws from the middle of the back of the phone.
  5. HTC myTouch 3G Camera Replacement, Access the Motherboard: paso 5, imagen 1 de 2 HTC myTouch 3G Camera Replacement, Access the Motherboard: paso 5, imagen 2 de 2
    • Pull out the antenna cover to access the motherboard.
  6. HTC myTouch 3G Camera Replacement, Dislodge the Back Plate: paso 6, imagen 1 de 2 HTC myTouch 3G Camera Replacement, Dislodge the Back Plate: paso 6, imagen 2 de 2
    • Insert a spudger into the gap between the frame and cover. Push downward with the spudger to separate the back plate from the phone.
    • With the spudger in the gap between the frame and cover, move the spudger around the edge of the of the phone to finish removing the back plate.
  7. HTC myTouch 3G Camera Replacement, Remove Back Screws: paso 7, imagen 1 de 2 HTC myTouch 3G Camera Replacement, Remove Back Screws: paso 7, imagen 2 de 2
    • Remove the 3 mm Phillips screw located on the side of the bottom left-hand corner of the phone.
    • Remove the 3 mm Phillips screw located on the top right-hand corner of the phone.
    • Do not remove any of the screws located on the actual circuit boards.
  8. HTC myTouch 3G Camera Replacement, Separate the Circuit Board: paso 8, imagen 1 de 3 HTC myTouch 3G Camera Replacement, Separate the Circuit Board: paso 8, imagen 2 de 3 HTC myTouch 3G Camera Replacement, Separate the Circuit Board: paso 8, imagen 3 de 3
    • Place a finger between the circuit board and front cover, and lift the circuit board gently.
    • Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
    • Finish separating the circuit board from the front panel.
  9. HTC myTouch 3G Camera Replacement, Camera: paso 9, imagen 1 de 1
    • Turn the device housing the circuit boards over to the side with the mounted camera.
    • Remove the three 3 mm Phillips head screws located on the top circuit board.
  10. HTC myTouch 3G Camera Replacement: paso 10, imagen 1 de 3 HTC myTouch 3G Camera Replacement: paso 10, imagen 2 de 3 HTC myTouch 3G Camera Replacement: paso 10, imagen 3 de 3
    • Locate the ribbon cable on the top circuit board.
    • Use a precision screwdriver to flip open the ribbon cable.
  11. HTC myTouch 3G Camera Replacement: paso 11, imagen 1 de 2 HTC myTouch 3G Camera Replacement: paso 11, imagen 2 de 2
    • Locate the two wired connections on the top circuit board.
  12. HTC myTouch 3G Camera Replacement: paso 12, imagen 1 de 2 HTC myTouch 3G Camera Replacement: paso 12, imagen 2 de 2
    • Remove the wired connections by using a squeeze-and-pull action.
  13. HTC myTouch 3G Camera Replacement: paso 13, imagen 1 de 3 HTC myTouch 3G Camera Replacement: paso 13, imagen 2 de 3 HTC myTouch 3G Camera Replacement: paso 13, imagen 3 de 3
    • Slowly lift the circuit board from the left.
    • Continue to flip the circuit board all the way over to the right; it will maintain a connection to the device.
  14. HTC myTouch 3G Camera Replacement: paso 14, imagen 1 de 3 HTC myTouch 3G Camera Replacement: paso 14, imagen 2 de 3 HTC myTouch 3G Camera Replacement: paso 14, imagen 3 de 3
    • The other side of the camera and circuit board should now be exposed.
    • Disconnect the ribbon cable with a precision screwdriver.
    • Remove the faulty camera and install a new one.
Conclusión
Una persona más ha completado esta guía.
Tony Tran
Miembro Desde 09/25/12
381 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 2-9, Propen Fall 2012 Miembro de Cal Poly, Team 2-9, Propen Fall 2012
CPSU-PROPEN-F12S2G9
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 1,509
