Introducción
This guide will explain how to install / remove the screen cover from the HTC Wizard 200.
Qué necesitas
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Herramienta utilizada en este paso:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
