Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Introducción
This guide will explain how to install / remove the keyboard slider on the HTC Wizard 200.
  1. Remove the back case with your fingernail to expose the battery. (Not shown in picture) Pull the black tab to remove the battery.
    • Remove the back case with your fingernail to expose the battery. (Not shown in picture)
    • Pull the black tab to remove the battery.
  2. Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
    • Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
  3. Work the spudger around the edge of the camera cover to release the clips. Work the spudger around the edge of the camera cover to release the clips.
    • Work the spudger around the edge of the camera cover to release the clips.
    • Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
    • There is a screw under the "void" sticker.
  4. Device rotated 180 degrees. Insert the flat end of a spudger into the crack between the front and rear cover.
    • Device rotated 180 degrees.
    • Insert the flat end of a spudger into the crack between the front and rear cover.
    • Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
  5. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
    • Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
  6. Pull off the back case panel. Pull off the back case panel.
    • Pull off the back case panel.
  7. Device rotated 180 degrees.
    • Use the spudger to pry off the camera.
  8. Device rotated 90 degrees CCW. You may need to remove a strip of orange anti-static tape (not pictured). Flip up the connector latch.
    • Device rotated 90 degrees CCW.
    • You may need to remove a strip of orange anti-static tape (not pictured).
    • Flip up the connector latch.
    • Use the tweezers to detatch the flexible connection.
  9. Device rotated 90 degrees CW.
    • Device rotated 90 degrees CW.
    • Slide the screen slider into the open position.
  10. Use the spudger to push out the motherboard.
    • Use the spudger to push out the motherboard.
  11. Use your hands to gently expose the underside of the motherboard. Use the spudger to pull off the flexible connection. Be careful not to pull apart the motherboard connection quickly, as the connection and cables could be damaged.
    • Use your hands to gently expose the underside of the motherboard.
    • Use the spudger to pull off the flexible connection.
    • Be careful not to pull apart the motherboard connection quickly, as the connection and cables could be damaged.
  12. Device rotated 180 degrees CW. Use the T5 Torx screwdriver to remove four 5mm screws that secure the keyboard slider to the main body. Use the T5 Torx screwdriver to remove four 5mm screws that secure the keyboard slider to the main body.
    • Device rotated 180 degrees CW.
    • Use the T5 Torx screwdriver to remove four 5mm screws that secure the keyboard slider to the main body.
Conclusión
Una persona más ha completado esta guía.
Kyle Champ
Miembro Desde 03/10/11
225 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 20-27, Maness Fall 2011 Miembro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 770
