Introducción
This guide will explain how to install / remove the keyboard slider on the HTC Wizard 200.
Partes
No se especificaron partes.
Remove the back case with your fingernail to expose the battery. (Not shown in picture)
Pull the black tab to remove the battery.
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the keyboard slider to the main body.
Una persona más ha completado esta guía.
