Introducción
Make sure you complete the previous guides.
  1. Power the phone off. Use your thumb to gently press downward and away from the camera to remove the battery cover.
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. Pull on the plastic tab to release the battery. Pull on the plastic tab to release the battery.
    • Pull on the plastic tab to release the battery.
  3. Use a plastic opening tool to remove the camera cover. Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. Remove the stylus from the phone.
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  6. Be Careful! Do not insert the spudger in between the keyboard and screen.  This could break the keyboard off the phone. If your phone contains a memory card, you may want to remove it before proceeding with this step. Insert spudger in the bottom corner as seen in the picture.  Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  7. Grip the speaker connector with your thumb and finger and gently pull up. Repeat for 2nd speaker.
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
  8. Locate the camera and pry off with the plastic opening tool or spudger.
    • Locate the camera and pry off with the plastic opening tool or spudger.
  9. Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
    • Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
  10. Remove the plastic tape to reveal the connector. Use your finger or plastic opening tool to flip the connector and release the cable.
    • Remove the plastic tape to reveal the connector.
    • Use your finger or plastic opening tool to flip the connector and release the cable.
  11. Use the plastic opening tool to carefully lift the motherboard off one corner at a time. Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
    • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
    • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
    • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
Conclusión
Eric W
Miembro Desde 22/09/11
41 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 20-28, Maness Fall 2011 Miembro de Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 720
