Saltar al contenido principal
HTC Warhawk Buttons Replacement
Qué necesitas
  1. HTC Warhawk Buttons Replacement, Buttons: paso 1, imagen 1 de 1
    • Take the back cover off the phone and take the battery out.
  2. HTC Warhawk Buttons Replacement: paso 2, imagen 1 de 1
    • Take a SL#2.5 screwdriver and pop the black piece off shown here
  3. HTC Warhawk Buttons Replacement: paso 3, imagen 1 de 1
    • Take a T5 screwdriver and unscrew the two screws seen here
  4. HTC Warhawk Buttons Replacement: paso 4, imagen 1 de 1
    • Unscrew the two screws on the back of the phone with a T5 screwdriver
  5. HTC Warhawk Buttons Replacement: paso 5, imagen 1 de 2 HTC Warhawk Buttons Replacement: paso 5, imagen 2 de 2
    • Take the SL#2.5 screwdriver and pry off the back cover
    • The phone should now look like the second picture
  6. HTC Warhawk Buttons Replacement: paso 6, imagen 1 de 1
    • Take the SL#2.5 screwdriver and lift up the white connector at the top right corner of the phone on the side with the circuit board
  7. HTC Warhawk Buttons Replacement: paso 7, imagen 1 de 2 HTC Warhawk Buttons Replacement: paso 7, imagen 2 de 2
    • Next lift up the camera lens from the board.
    • It should now look like the second picture
    • Then lift up the circuit circled in red on the second picture
  8. HTC Warhawk Buttons Replacement: paso 8, imagen 1 de 2 HTC Warhawk Buttons Replacement: paso 8, imagen 2 de 2
    • Take the SL#2.5 screwdriver and pry off the volume buttons on the side of the phone
    • The circuit board should now be detached from the LCD part of the phone
  9. HTC Warhawk Buttons Replacement: paso 9, imagen 1 de 1
    • Next take the SL#2.5 screwdriver and pry the buttons off the phone and replace with the new ones
Conclusión
Equipo
UW Stout, Team 5-3, Zhou Fall 2011 Miembro de UW Stout, Team 5-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 781
