Introducción
Follow this guide to replace one or both headphones on your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Qué necesitas
Peel off the thin piece of padding covering the headphone screw for each headphone you're replacing.
Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
Insert an opening pick under the headphone pad and pry up to unclip it from the headphone.
Una persona más ha completado esta guía.
