Saltar al contenido principal
HTC Vive Pro Headphone Replacement
Qué necesitas
  1. HTC Vive Pro Headphone Replacement, Remove the head strap padding: paso 1, imagen 1 de 3 HTC Vive Pro Headphone Replacement, Remove the head strap padding: paso 1, imagen 2 de 3 HTC Vive Pro Headphone Replacement, Remove the head strap padding: paso 1, imagen 3 de 3
    • Peel off the thin piece of padding covering the headphone screw for each headphone you are replacing.
  2. HTC Vive Pro Headphone Replacement, Unscrew the headphone(s): paso 2, imagen 1 de 2 HTC Vive Pro Headphone Replacement, Unscrew the headphone(s): paso 2, imagen 2 de 2
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
  3. HTC Vive Pro Headphone Replacement, Remove the headphone(s): paso 3, imagen 1 de 3 HTC Vive Pro Headphone Replacement, Remove the headphone(s): paso 3, imagen 2 de 3 HTC Vive Pro Headphone Replacement, Remove the headphone(s): paso 3, imagen 3 de 3
    • Remove the headphone(s).
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
Miembro Desde 02/25/19
65,203 Reputación
288 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 59
Todo El Tiempo: 847
