Saltar al contenido principal
HTC Vive Pro Facerest Replacement
Qué necesitas
  1. HTC Vive Pro Facerest Replacement, Reposition the head strap: paso 1, imagen 1 de 2 HTC Vive Pro Facerest Replacement, Reposition the head strap: paso 1, imagen 2 de 2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro Facerest Replacement, Unplug the All-In-One Cable: paso 2, imagen 1 de 2 HTC Vive Pro Facerest Replacement, Unplug the All-In-One Cable: paso 2, imagen 2 de 2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: paso 3, imagen 1 de 3 HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: paso 3, imagen 2 de 3 HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: paso 3, imagen 3 de 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro Facerest Replacement, Remove the top strap: paso 4, imagen 1 de 2 HTC Vive Pro Facerest Replacement, Remove the top strap: paso 4, imagen 2 de 2
    • Separate the top strap from itself where the velcro secures it.
  5. HTC Vive Pro Facerest Replacement: paso 5, imagen 1 de 3 HTC Vive Pro Facerest Replacement: paso 5, imagen 2 de 3 HTC Vive Pro Facerest Replacement: paso 5, imagen 3 de 3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to remove it.
  6. HTC Vive Pro Facerest Replacement: paso 6, imagen 1 de 3 HTC Vive Pro Facerest Replacement: paso 6, imagen 2 de 3 HTC Vive Pro Facerest Replacement: paso 6, imagen 3 de 3
    • Feed the top strap through the clip on the headset to fully remove it.
  7. HTC Vive Pro Facerest Replacement, Remove the front side foam pads: paso 7, imagen 1 de 3 HTC Vive Pro Facerest Replacement, Remove the front side foam pads: paso 7, imagen 2 de 3 HTC Vive Pro Facerest Replacement, Remove the front side foam pads: paso 7, imagen 3 de 3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro Facerest Replacement, Remove two rubber spacers: paso 8, imagen 1 de 3 HTC Vive Pro Facerest Replacement, Remove two rubber spacers: paso 8, imagen 2 de 3 HTC Vive Pro Facerest Replacement, Remove two rubber spacers: paso 8, imagen 3 de 3
    • Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
    • Gently pry the rubber spacers out of the head strap.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: paso 9, imagen 1 de 2 HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: paso 9, imagen 2 de 2
    • Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro Facerest Replacement, Remove the head strap: paso 10, imagen 1 de 2 HTC Vive Pro Facerest Replacement, Remove the head strap: paso 10, imagen 2 de 2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro Facerest Replacement: paso 11, imagen 1 de 1
    • Remove the two plastic spacers underneath the previously removed screws from the headset.
  12. HTC Vive Pro Facerest Replacement: paso 12, imagen 1 de 3 HTC Vive Pro Facerest Replacement: paso 12, imagen 2 de 3 HTC Vive Pro Facerest Replacement: paso 12, imagen 3 de 3
    • Thread the headphone speaker wires out through the ends of the head strap.
  13. HTC Vive Pro Facerest Replacement, Remove the outer shell: paso 13, imagen 1 de 3 HTC Vive Pro Facerest Replacement, Remove the outer shell: paso 13, imagen 2 de 3 HTC Vive Pro Facerest Replacement, Remove the outer shell: paso 13, imagen 3 de 3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. HTC Vive Pro Facerest Replacement: paso 14, imagen 1 de 2 HTC Vive Pro Facerest Replacement: paso 14, imagen 2 de 2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. HTC Vive Pro Facerest Replacement: paso 15, imagen 1 de 3 HTC Vive Pro Facerest Replacement: paso 15, imagen 2 de 3 HTC Vive Pro Facerest Replacement: paso 15, imagen 3 de 3
    • Insert an opening pick into the crease between the two halves of the outer shell.
    • Slide the opening pick through the crease to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
    • Continue sliding the opening pick through each crease until all clips have been dislodged.
  16. HTC Vive Pro Facerest Replacement: paso 16, imagen 1 de 3 HTC Vive Pro Facerest Replacement: paso 16, imagen 2 de 3 HTC Vive Pro Facerest Replacement: paso 16, imagen 3 de 3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Use caution not to snag any of the ribbon cables underneath.
  17. HTC Vive Pro Facerest Replacement, Remove the facerest: paso 17, imagen 1 de 2 HTC Vive Pro Facerest Replacement, Remove the facerest: paso 17, imagen 2 de 2
    • Partially separate the facerest and the sensor array to access the daughterboard.
  18. HTC Vive Pro Facerest Replacement: paso 18, imagen 1 de 2 HTC Vive Pro Facerest Replacement: paso 18, imagen 2 de 2
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
  19. HTC Vive Pro Facerest Replacement: paso 19, imagen 1 de 3 HTC Vive Pro Facerest Replacement: paso 19, imagen 2 de 3 HTC Vive Pro Facerest Replacement: paso 19, imagen 3 de 3
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
  20. HTC Vive Pro Facerest Replacement: paso 20, imagen 1 de 2 HTC Vive Pro Facerest Replacement: paso 20, imagen 2 de 2
    • Slide the facerest out of the front assembly.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
Miembro Desde 02/25/19
65,619 Reputación
288 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 439
