Introducción
The HTC Vive's lenses can become scratched, cracked, or dirty with use. This guide will show you how to replace one or both of the HTC Vive lenses.
Herramientas
Partes
No se especificaron partes.
Slide the HTC panel covering the cables forward, away from the Vive.
Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
Pull the facerest cushion off away from the Vive, separating the hook and loop tape.
Orient the Vive so that the camera is facing towards you and the connector ports are facing upwards.
There are four screws you need to remove that are covered with small black stickers (two on top, two on bottom).
Use a plastic opening tool to gently pry up the left side of the outer sheath.
Slide the left side of the sheath outwards.
Remove the five 4mm Philips #00 screws holding the sensor array to the motherboard.
Remove the two 4mm Philips #00 screws holding the sensor array to the midframe.
Lift the sensor array away from the rest of the Vive until the camera cable tugs back and hold it in place.
Disconnect the camera by lifting its ribbon cable up and away from the motherboard using a pair of ESD safe tweezers.
Lift the sensor array upwards away from the motherboard to separate the array from the device fully.
Loosen the three ribbon cables that are attached to the motherboard by grabbing the tabs on the side of the ribbon cables' connectors and pulling gently outwards.
Fully detach the same three ribbon cables by grabbing each cable with tweezers and sliding them outwards horizontally.
Grab the tabs on the side of the ribbon cable's connector and pull gently outwards to loosen it.
Remove the ribbon cable for the power button by grabbing the cable with tweezers and sliding it outwards horizontally.
Pivot the bottom rod attached to the eyepieces outwards from the facerest to free the eyepieces.
Pull facerest from the eyepieces to separate the parts.
Remove the four 2mm #00 Philips head screws holding the screen in place from the eyepiece assembly.
Hold your hand in front of the lens and be ready to catch the lens during its removal.
From the inside of the black plastic housing, push gently around the edges of the lens to remove it.
6 personas más completaron esta guía.
8 comentarios
Or… you can simply use an exacto knife and pry the lenses out without taking the entire HMD apart!
You can insert a scalpel type knife between the lens and the housing and work your way around.
I’ve got to agree . This is the absolute worst way to do what’s essentially a simple operation. So many ways this could go wrong for the user if they’re not careful.
This reeks of click bait re-purposing of the tear-down coverage.
This has to be the most overly complicated approach for a VERY simple fix. Takes about 5 seconds to pop out the lenses by carefully prying at the flat edge with a butter knife, exacto knife, etc.
Agreed! what rubbish…
