Introducción
Use this guide to replace the HTC Vive controller saucer panels. You will need to remove these panels before you can access any other components of the controller. Remove the top and bottom saucer panels gently. The plastic clips that hold the saucer panels on can break if handled too roughly.
Herramientas
Partes
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
5 personas más completaron esta guía.
3 comentarios
Where do you get the replacement parts?
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
