Introducción
The HTC Vive controller grip buttons may be weak or faulty from extended use or from being dropped on its side. Use caution when removing the rubber tabs to avoid damage. This guide will show you how to replace the grip buttons.
Qué necesitas
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the silver rectangular plate.
Un comentario
It’s all fine and dandy but this part is nowhere to be found
