Saltar al contenido principal
Introducción
Use this guide to remove the compartment cover assembly on an HTC Vive.
Herramientas
No se especificaron herramientas.
  1. Be sure to power down and disconnect your Vive before beginning. Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
  2. Slide the top part of the head strap through its metal loop on the headset to remove it. Slide the top part of the head strap through its metal loop on the headset to remove it.
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
  3. Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset. Lift the cover away from the headset and slide it up the cables until it's out of the way. Lift the cover away from the headset and slide it up the cables until it's out of the way.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  4. Lift the HDMI cable straight up to unplug it from the headset. Lift the HDMI cable straight up to unplug it from the headset.
    • Lift the HDMI cable straight up to unplug it from the headset.
  5. Repeat the lifting and unplugging process with the remaining USB, power, and audio cables. Repeat the lifting and unplugging process with the remaining USB, power, and audio cables. Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  6. Carefully slide the compartment cover assembly over the plugs and remove it. Carefully slide the compartment cover assembly over the plugs and remove it.
    • Carefully slide the compartment cover assembly over the plugs and remove it.
Conclusión
Adam O'Camb
Miembro Desde 11/04/15
140,072 Reputación
407 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
137 Miembros
16,410 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 210
