Saltar al contenido principal
Introducción
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Partes
No se especificaron partes.
  1. Remove the back panel by sliding up.
    • Remove the back panel by sliding up.
  2. Remove the battery.
    • Remove the battery.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the 2 torx-head screws located at the top corners of the phone using the T5 Torx Screwdriver.
    • Remove the 2 torx-head screws located at the top corners of the phone using the T5 Torx Screwdriver.
  5. Remove the plastic speaker casing above the battery slot.
    • Remove the plastic speaker casing above the battery slot.
  6. Use the plastic opening tool to remove the speaker.
    • Use the plastic opening tool to remove the speaker.
Conclusión
Una persona más ha completado esta guía.
Andrew Brooks
Miembro Desde 13/04/11
101 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-12, Regan Spring 2011 Miembro de Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,069
