Saltar al contenido principal
HTC Touch Pro CDMA Verizon Keyboard Replacement
Qué necesitas
  1. HTC Touch Pro CDMA Verizon Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover (not pictured) to your phone.
  2. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 2, imagen 1 de 2 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 2, imagen 2 de 2
    • To remove the battery, place your thumb beneath the tab and begin to lift.
    • Pinching the battery, lift up at an angle from the bottom of the phone.
  3. HTC Touch Pro CDMA Verizon Keyboard Replacement, Basic Parts: paso 3, imagen 1 de 1
    • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
    • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
  4. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 4, imagen 1 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 4, imagen 2 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 4, imagen 3 de 3
    • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
    • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
  5. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 5, imagen 1 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 5, imagen 2 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 5, imagen 3 de 3
    • Next, remove the casing that covers the camera and motherboard.
    • To do this, place your thumbnail in any of the grooves along either side and pry it open.
  6. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 6, imagen 1 de 2 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 6, imagen 2 de 2
    • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
    • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
  7. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 7, imagen 1 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 7, imagen 2 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 7, imagen 3 de 3
    • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
  8. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 8, imagen 1 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 8, imagen 2 de 3 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 8, imagen 3 de 3
    • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
    • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
  9. HTC Touch Pro CDMA Verizon Keyboard Replacement, Keyboard: paso 9, imagen 1 de 1
    • Move the black slider over to the side without the keyboard ribbon. This is done as to allow the display ribbon to slide out later.
    • Using a PH 0 screwdriver, remove the 4 screws on the black slider.
  10. HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 10, imagen 1 de 2 HTC Touch Pro CDMA Verizon Keyboard Replacement: paso 10, imagen 2 de 2
    • Pry the keyboard away from the screen. Open on the side containing the keyboard ribbon.
Conclusión
Jack Bowen
Miembro Desde 04/09/11
79 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 20-67, Walters Spring 2011 Miembro de Cal Poly, Team 20-67, Walters Spring 2011
CPSU-WALTERS-S11S20G67
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,058
