Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
  1. First, gently press on the back plate and push down toward the camera. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
  3. Remove the 4 screws using the T6 screw driver.
    • Remove the 4 screws using the T6 screw driver.
  4. Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
    • Lift the plastic cover near the memory card slot.
  5. Remove the two Phillips #00 screws from the backside of the screen.
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  7. Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  8. Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  9. Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  10. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
  11. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool.
    • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
  12. Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Gently lift the connectors.
  13. Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
    • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
  14. With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
    • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
Conclusión
2 personas más completaron esta guía.
Zhaowei Zhang
Miembro Desde 28/04/11
112 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 3,442
