Saltar al contenido principal
HTC Touch Pro 2 Logic Board Replacement
Qué necesitas
  1. HTC Touch Pro 2 Logic Board Replacement, Battery: paso 1, imagen 1 de 3 HTC Touch Pro 2 Logic Board Replacement, Battery: paso 1, imagen 2 de 3 HTC Touch Pro 2 Logic Board Replacement, Battery: paso 1, imagen 3 de 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Logic Board Replacement: paso 2, imagen 1 de 2 HTC Touch Pro 2 Logic Board Replacement: paso 2, imagen 2 de 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners
  3. HTC Touch Pro 2 Logic Board Replacement, Housing: paso 3, imagen 1 de 2 HTC Touch Pro 2 Logic Board Replacement, Housing: paso 3, imagen 2 de 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Logic Board Replacement: paso 4, imagen 1 de 3 HTC Touch Pro 2 Logic Board Replacement: paso 4, imagen 2 de 3 HTC Touch Pro 2 Logic Board Replacement: paso 4, imagen 3 de 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
Conclusión
2 personas más completaron esta guía.
Melinda Phan
Miembro Desde 04/17/11
438 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 9-64, Walters Spring 2011 Miembro de Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 4,539
