Saltar al contenido principal
HTC Touch Pro 2 Keyboard Replacement
Qué necesitas
  1. HTC Touch Pro 2 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 HTC Touch Pro 2 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 HTC Touch Pro 2 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Keyboard Replacement: paso 2, imagen 1 de 2 HTC Touch Pro 2 Keyboard Replacement: paso 2, imagen 2 de 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners
  3. HTC Touch Pro 2 Keyboard Replacement, Housing: paso 3, imagen 1 de 2 HTC Touch Pro 2 Keyboard Replacement, Housing: paso 3, imagen 2 de 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Keyboard Replacement: paso 4, imagen 1 de 3 HTC Touch Pro 2 Keyboard Replacement: paso 4, imagen 2 de 3 HTC Touch Pro 2 Keyboard Replacement: paso 4, imagen 3 de 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
  5. HTC Touch Pro 2 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 3 HTC Touch Pro 2 Keyboard Replacement, Keyboard: paso 5, imagen 2 de 3 HTC Touch Pro 2 Keyboard Replacement, Keyboard: paso 5, imagen 3 de 3
    • Peel off the yellow ribbon shown slowly.
    • Unscrew the fours screws shown in red squares (two in each square) using a 00 screwdriver.
    • After the screws are out, you will be able to easily take off the small metal pieces circled in red. Please do so.
  6. HTC Touch Pro 2 Keyboard Replacement: paso 6, imagen 1 de 3 HTC Touch Pro 2 Keyboard Replacement: paso 6, imagen 2 de 3 HTC Touch Pro 2 Keyboard Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Slowly pull dual black strip off using force.
    • Behind the dual black strip is very sticky piece of grey tape. Use tweezers (preferably ones with ridges) to peel off the tape. Be careful not to rip it.
  7. HTC Touch Pro 2 Keyboard Replacement: paso 7, imagen 1 de 2 HTC Touch Pro 2 Keyboard Replacement: paso 7, imagen 2 de 2
    • Lift ZIF connectors up.
    • Carefully lift keyboard frame away from display screen.
    • You now have the keyboard detached.
Conclusión
Una persona más ha completado esta guía.
Melinda Phan
Miembro Desde 04/17/11
438 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 9-64, Walters Spring 2011 Miembro de Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 4,367
