Introducción
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Partes
No se requieren partes.
  1. Remove the back panel by sliding it up.
    • Remove the back panel by sliding it up.
  2. Remove the battery.
    • Remove the battery.
  3. Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Use the plastic opening tool to remove the front panel from the phone. Be sure to unplug the front button cable from the inside of the phone.
    • Use the plastic opening tool to remove the front panel from the phone.
    • Be sure to unplug the front button cable from the inside of the phone.
  6. Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
    • Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  7. Separate the motherboard from the black plastic casing. Unplug the black and red wire from the motherboard.
    • Separate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  8. Lift the black lever next to the orange ribbon cable to remove the LCD screen.
    • Lift the black lever next to the orange ribbon cable to remove the LCD screen.
Conclusión
Una persona más ha completado esta guía.
callum rowland
Miembro Desde 18/04/11
247 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-12, Regan Spring 2011 Miembro de Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 10,640
