Introducción
Use this guide to replace a speaker that no longer outputs sound.
Qué necesitas
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Remove the two Phillips screws securing rear inner frame to device.
Casi Terminas!
Conclusión
