Saltar al contenido principal
HTC Thunderbolt Rear Frame Replacement
Qué necesitas
  1. HTC Thunderbolt Rear Frame Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Rear Frame Replacement: paso 2, imagen 1 de 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Rear Frame Replacement, Battery: paso 3, imagen 1 de 2 HTC Thunderbolt Rear Frame Replacement, Battery: paso 3, imagen 2 de 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Rear Frame Replacement, MicroSD Card: paso 4, imagen 1 de 2 HTC Thunderbolt Rear Frame Replacement, MicroSD Card: paso 4, imagen 2 de 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt Rear Frame Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. HTC Thunderbolt Rear Frame Replacement, Rear Frame: paso 6, imagen 1 de 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. HTC Thunderbolt Rear Frame Replacement: paso 7, imagen 1 de 2 HTC Thunderbolt Rear Frame Replacement: paso 7, imagen 2 de 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. HTC Thunderbolt Rear Frame Replacement: paso 8, imagen 1 de 1
    • Remove the two Phillips screws where the plastic cover was.
  9. HTC Thunderbolt Rear Frame Replacement: paso 9, imagen 1 de 2 HTC Thunderbolt Rear Frame Replacement: paso 9, imagen 2 de 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. HTC Thunderbolt Rear Frame Replacement: paso 10, imagen 1 de 3 HTC Thunderbolt Rear Frame Replacement: paso 10, imagen 2 de 3 HTC Thunderbolt Rear Frame Replacement: paso 10, imagen 3 de 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 19-45, Regan Winter 2013 Miembro de Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 495
