Introducción
Use this guide to replace a sticky or unresponsive power button.
Qué necesitas
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Herramienta utilizada en este paso:Tweezers$4.99
Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
Use a pair of tweezers to pull the capacitive button cable out of its socket.
Flip the LCD over so that it is facing downward.
Pry out the power button with a plastic opening tool.
You have now removed the power button.
